Yale GLP060:
No forward
The lift truck starts right up flip to forward and it doesn't go. Flip switch to reverse and it goes. No forward? Any suggestions on where to look?
  • Posted 16 Oct 2020 03:17
  • Discussion started by Hangover
  • Arizona, United States
Without serier number hard to tell but if older model l would open covers on steering column and look at switches some had four switches two in center and two on each end one is forward and one reverse check to see when in gear that switch is working sometimes switch gets worn and does not make contact with arm also l have seen wiring coming off switch if checks out go to coils on top of trans one is forward and one reverse normally both have common ground when in gear forward should get positive from switch and when in reverse should get the same.the two in center switches are natural for starter
  • Posted 30 Apr 2022 08:21
  • Reply by Scott_
I am having the same issue with my GLP050. Did you ever find a solution?
  • Posted 30 Apr 2022 07:21
  • Reply by Running_M
  • New Mexico, United States
Your Focus
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
Zhejiang UN Forklift Co., Ltd
edition #1234 - 12 June 2025
