Toyota 62-7FD25:
No forward, reverse ok
Model 62-7FD25 forklift with 6800h not moving forward, reverse ok. I have had the valve cover off completely disassembled and cleaned thoroughly. Solenoids ok and tried switching them, no difference. Electricity ok, 14V at both solenoids. Oil level ok. Pressure at M port is about 13 bar at idle, C port about the same pressure when selecting forward or reverse gear. Any other things to try or do I start taking the engine and gearbox out? When I drained the oil it looked red and clean, no junk or sludge came out.
  • Posted 25 Nov 2015 00:30
  • Discussion started by christian_s
  • Pedersore, Finland
I am having this same problem on an 8fgcu30 please someone help rebuilt trans found several worn plates but still no fwd have reverse and and good solenoid a free moving spools
  • Posted 26 Dec 2015 05:17
  • Reply by johnny_a
  • New Jersey, United States
If I get pressure on the Clutch port in both forward and reverse, does that mean the problem is not in the valve cover?
  • Posted 7 Dec 2015 17:05
  • Reply by christian_s
Left the engine running and in reverse gear with wheels off the ground to warm up the oil. When shifting fwd and reverse the gearbox makes the same click and hissing sound both directons, but the wheels only turn backwards. No drive in fwd, but slowly spinning backwards.
  • Posted 26 Nov 2015 18:27
With the wheels off the ground they are spinning backwards in neutral and fwd gear also. Faster spinning when in reverse and with oil flow noise as expected. No oil noise in fwd and neutral but still spinning backwards.
  • Posted 26 Nov 2015 18:01
Tested the clutch packs by showing a hose with compressed air down the two holes. Both clutches seem to work as they slam shut when applying pressure.. So it seems the problem must be in the valve cover anyway, even though it was thoroughly cleaned..? Although all valves seem to move freely in the cover.
  • Posted 26 Nov 2015 09:30
if you get no reaction -at all-, even when you jumper to energize the solenoids, you may have a valve body spool stuck or it's time for a trans rebuild.
  • Posted 25 Nov 2015 23:35
  • Reply by edward_t
I havent tried lifting it yet. Reverse gear works fine though. Can drive backwards all day. No reaction on forward.
  • Posted 25 Nov 2015 15:50
do the drive wheels turn equal in both directions, when they are in the air and unit in neutral with no park brake on?
  • Posted 25 Nov 2015 11:37
  • Reply by edward_t
Linda Häkkilä Linda Häkkilä
Dubuque, IA, United States
Louisville, KY, United States
