No Drive
Hi guys!
Just wanted some help!! I have an old XL and it has hydraulics but no drive. It is fitted with a monotrol pedal. when it is keyed on the power steer motor is not running. I noticed a timer relay box near the solenoid, and im not getting any power out of one of the terminals to go to the solenoid. Im not sure if this relay is faulty and completes the circuit for drive?
Any Help would be great!!
Cheers
Steve
  • Posted 30 Aug 2016 19:24
  • By Stevros
  • joined 30 Aug'16 - 1 message
  • Victoria, Australia
I actually found the problem. In my case the 1A contractor coil wasn't operating so I put in a new contractor assembly but if the tips on the contractor are burnt that may be the issue. I would also check the seat switch. If you are getting a code on the display for 01 it is the operator presence switch.
Let me know what you find.
  • Posted 4 Oct 2016 02:28
  • By kyle93
  • joined 4 Oct'16 - 13 messages
I am currently having the same issue. Did you ever find a solution?
  • Posted 4 Oct 2016 01:54
  • By kyle93
Bolzoni SpA (Group HQ)
