No display, no travel, no lift
Hi Guys, I have a Toyota 7FBEU20 and all of the sudden when backing out of a lift the display went dark and no travel or lift functions working. The back up alarm, horn and strobe light are still working. I have checked all fuses, including the fuse under the passenger side step - all good. the battery is fully charged and has 48v at the connector when unplugged. When battery is plugged in there is only 10v. I removed battery and checked all cables under the tray - all good. I removed the truck side battery cables from the main contactor and pump controller and the voltage reads 48v. Wondering if I have a controller issue? Any Ideas?
  • Posted 13 Dec 2023 08:50
  • By Scott_Palmer
  • joined 7 Sep'22 - 4 messages
Scott Palmer
I would check for short to ground and short to frame from battery. Then reconnect motor controller and test contactor...if tests good reconnect and check ignition switch and all fuses...have had fuses good but wires behind fuses with shorted wires in the past also. If you have a good battery in another truck...pull good truck next to backwards and hook good battery up...if it works..short to frame or ground through battery
  • Posted 15 Dec 2023 16:22
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
So, you say the battery shows only 10 volts when you plug it in? If you're measuring at the connector, compare the voltage before the battery connector to the after truck connector. Stab the cables if necessary.
  • Posted 15 Dec 2023 00:53
  • By ErichO
  • joined 26 Oct'21 - 83 messages
  • Washington, United States
UN Forklift FD40T
Terberg YT223
REPOWERTEK Inc
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
UN Forklift FD40T
Terberg YT223
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
