Toyota 4FB SERIES:
no convertor pressure
I took three gauge readings (A) (B) and (C ), had no pressure on C. Not at idle, or 2000 rpm. but had some pressures at A and B.lift moves slow forward and backward. Can you help?
  • Posted 14 Oct 2017 04:41
  • Discussion started by 1968496
  • Michigan, United States
yes I did and the wheels turn in both directions, but on the ground it is slow both ways. doI need to pull the trans?
  • Posted 18 Oct 2017 02:10
  • Reply by 1968496
On the job
morning, did you have the front wheels off the ground?
i will come back to you just now.
  • Posted 17 Oct 2017 15:45
  • Reply by Africa
  • Eastern Cape, South Africa
edition #1228 - 1 May 2025
F. Uchiyama
