No codes, non operational
I picked up this pallet jack at an auction. It has fully charged fresh batteries and the controller status light flashes yellow but that's it. No codes and the handle doesn't engage it.
Any suggestions.
Thanks!
  • Posted 13 Nov 2013 11:30
  • By bad1129
  • joined 8 Nov'13 - 11 messages
  • New Jersey, United States
Hahaha I wasn't aware that I needed to use a pin to get it going!
  • Posted 7 Dec 2013 10:50
  • By bad1129
Way to go Stam! The old `turn the switch on trick` fixes it again! :)
  • Posted 7 Dec 2013 10:42
  • By EasiTek
You made my day, thanks!
  • Posted 7 Dec 2013 10:17
  • By bad1129
you will always get a c28 if the red switch gets flipped off.
the red button on the keypad is for off.
for the c14, the truck was turned on with the handle down.
i think your good to go.
  • Posted 7 Dec 2013 09:12
  • Modified 7 Dec 2013 09:36 by poster
  • By stam
That was it! They didn't tell me about that when I brought it.
Now I get a C-28 and C-14 error on it when the EPO switch is in the off position and it has been unlocked. Once I flip the EPO switch on, the machine runs fine, lifts, lowers and moves as it should.
Any ideas on these codes?
  • Posted 7 Dec 2013 06:55
  • By bad1129
are you turning it on? there is a keypad on the back of the control head, there is a pin number you have to enter to turn it on, the red switch near the battery connector is the epo switch. usually push #1 then green to turn on.
  • Posted 3 Dec 2013 07:41
  • Modified 7 Dec 2013 09:49 by poster
  • By stam
Do you know if there is a parts systemic available for this lift or can you help me identify this solenoid?
  • Posted 3 Dec 2013 03:31
  • By bad1129
check the lift solenoid if it is stuck closed you can get this scenario.
  • Posted 21 Nov 2013 09:15
  • By forktech418
  • joined 31 May'12 - 19 messages
Anybody have any ideas on this?
  • Posted 17 Nov 2013 04:42
  • By bad1129
Other than the flashing status light on the controller nothing.
  • Posted 13 Nov 2013 12:26
  • By bad1129
What does it do? horn?, does it lift or is it completely dead?
  • Posted 13 Nov 2013 12:16
  • By EasiTek
Maxlion ESD15M
Maxlion FB30LI
