NO AUXILIARY FUNTIONS RAYMOND
I NEED AID WITH THIS MACHINE SINCE SYSTEM CARD DOES NOT SEND SIGNAL BY THE PS10 TOWARDS THE SELENOID, REPLACE CONTINUOUS SYSTEM CARD AND WITHOUT VOLTAGE
EZ-A-02-24376
EASI DR30TT
  • Posted 5 Jan 2009 10:40
  • By jose_m
  • joined 5 Jan'09 - 13 messages
  • d.n, Dominican Republic
thanks resolute problem
  • Posted 20 Jan 2009 09:08
  • By jose_m
Check the multifunction handle as well, if it still has the old pots installed. The new handles have optical sensors (much better).
Also check the fuse under the dashboard on the distribution block will kill the aux functions (it is often ommitted from the wiring diagram). Also, is it coughing up any fault codes?
  • Posted 20 Jan 2009 05:41
  • By Arclite
  • joined 20 Jan'09 - 4 messages
check your coil driver cards. then check wiring from cards to coils
  • Posted 14 Jan 2009 23:18
  • By JDBurton
  • joined 4 Jul'07 - 96 messages
  • Virginia, United States
December 03, 2025 - New Delhi, India
Spencer/Sheldon/Sioux Rapids, IA, United States
