nissan service info
can anyone help me with fuel/oil filter part numbers for a nissan fgj02 circa 1995 with a td 27 engine,also valve clearances,thanks
  • Posted 5 Nov 2009 07:55
  • Discussion started by markg
  • n lincs, United Kingdom
thanks for your help guys,all the best.
  • Posted 6 Nov 2009 07:01
  • Reply by markg
Nissan OEM #'s are:
Air- 16546-51H00 ( this is what is on most J models with a TD27)
Oil - 15208-43G00
Fuel - 16405-T9005
Fuel filter O-ring- 16407-W4900
(replace this O-ring when you change fuel filter,a lot of poorly trained or sloppy techs don't and loose this when they pull the old filter off,or don't know it's there and start having issues with starting.) It sits at the top of the tube on the fuel pump/bleeder.
Take the time and just remove the battery to gain access to the filter, it make the job go a whole lot smoother with it out of the way.
  • Posted 5 Nov 2009 14:58
  • Reply by roadtech
nissan engine use a quite std filters for there engine
crossland numbers fuel 370 or 5013 oil 2029/694 or 2048
valve clearances 0.35mm [0.014 in]
  • Posted 5 Nov 2009 09:27
  • Reply by greasespoon
  • somerset, United Kingdom
edition #1229 - 8 May 2025
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
Toyota 8FGCU25
Flesherton, Ontario, Canada
Aichi RX07B
