Nissan power steering problems
A power transistor failed causing damage to an output transistor for the power steering on the main circuit board. We have been told by Nissan that this was due to excessive use of the steering lock causing damage to the current limiting circuit and that repairing the circuit may cause further damage. A new circuit board is £2500.
Our concern is that due to a small warehouse we regularly use the steering lock. Surely the Fork truck is desgined for regular steering lock use and that the current limiting circuit should be desgined to protect the system from any problems. What certainty do we have that 18months after buying a new circuit board the same thing happens again. What risks are there in reparing the board.
Can somebody please advise us as we are only a small company.
  • Posted 21 Jan 2006 00:46
  • Discussion started by aled_w
  • wales, United Kingdom
Showing items 1 - 15 of 19 results.
Marengo since Aled posted this nearly 10 years ago, i am sure the unit is out of warranty by now. But any follow up no matter how long after an original post is still helpful. And as always any input is always helpful.
  • Posted 13 Aug 2015 22:44
  • Reply by RCAV8TOR
  • Alabama, United States
Hello Aled: It sounds to me like you're talking to the Warranty department in USA. Did they also tell you that this was the first time they ever heard a complaint like this?
  • Posted 12 Aug 2015 01:48
  • Reply by Marengo
  • Michigan, United States
Hey Barry M where in the bop are u, do u still repairs Nissan circuit boards ? off a P01 BE. Im in Hamilton, how can I contact you ?Hey Barry M can you sms me so I can contact you please, 0272882076, cheers JD
  • Posted 11 Aug 2015 20:18
  • Modified 12 Aug 2015 08:41 by poster
  • Reply by jay_dee
  • New South Wales, Australia
2 heads are better than 1
I have repaired many of these cards with this problem over the years and so far the repair cost has always been under NZ$300. I often wonder about some of the outrageous amounts some people charge for these repairs.
  • Posted 5 Mar 2013 15:12
  • Reply by Barry_m
  • B.O.P., New Zealand
Is this part of a Nissan service gram? If so could you send it to me?
  • Posted 3 Jul 2010 04:39
  • Reply by freetman
on po 1/2 when you have replaced the igbt (use 100 amp) hold down buttons 1 and 3 swith on and go up to steering and change current limit and steering effort to 85% from the original 110%.(official nissan service information)
  • Posted 2 Jul 2010 04:29
  • Reply by micky
  • west sussex, United Kingdom
If you cannot get the board repaired and are willing to use it with it as is then you can always add a contactor in series with the motor and feed the contactor coil supply off some form of interlock switch handbrake, seat switch etc. Most likely will still have a error code on the display though, but should work your steer motor.
  • Posted 2 Jun 2010 05:55
  • Reply by elektrodrive
This problem can be fixed for under $1000.00.
Send me board and I will repair.
I will return the repaired board to you
with a new set (2) of IGBT transistors.
I have done about eight in the last year or so
with no returns, incuding two for Nissan!
  • Posted 5 Apr 2010 11:38
  • Reply by bigd_b
  • Victoria, Australia
29327-2K011-F1 (sold in pairs)
Information from Customer Satisfaction department-Parts
  • Posted 5 Oct 2009 00:35
  • Reply by diego_c
  • Buenos Aires, Argentina
Dear freetman,
You can try refer to RS component or farnell component for 75/100 amp IGBT.
Normally if I found steering malfunction, we will modify using local make steering board.
  • Posted 28 Mar 2008 15:34
  • Reply by mok_e
  • JOHOR, Malaysia
Does anybody know the part number is for the 75 amp IGBT's?
  • Posted 21 Mar 2008 04:48
  • Reply by freetman
i think he means they steer it till it hits the stops and holds it there and the steer valve goes into bypass wich works the motor harder
all traction/pump/steer systems will suffer if ur not religious with ur charging habits
the difference between old and new equipment is the cost of contactor tips and recs over entire transistor boards
itll take 5 breakdowns of an old scr system to equal 1 blown board
hard lessons to learn
here in ny ppl are very stubborn trying to push 20 hours use on a 4 hour charge and they dont understand y i am there twice a week lol
when the voltage is low the amps go up and so does resistance so if there is a bad connection/ solder point or anything the problem increases exponentially as resistance increases as bad components get hotter and poof ur out 4500 us dollars on 1 call
also check for worn motor bearings or any restrictions/ crimped hydraulic lines in the steer system
  • Posted 16 Jul 2006 07:16
  • Modified 16 Jul 2006 07:20 by poster
  • Reply by justinm
What do you mean by steering lock?
  • Posted 13 Jul 2006 00:25
  • Reply by freetman
Also check the steer motor for earth leakage as carbon build up can cause the units to fail.
  • Posted 7 Jun 2006 07:18
  • Reply by adrian_w
  • East Yorkshire, United Kingdom
Premier Mechanical Handling,
Hull.
UK
Hi welshman.
its true that you must have a PO2 that a very reliable truck generally-However the weak parts are the steering & the pump contacter.
We here in Canada have had a lot of problems with the steering issues.
It is the weakest part of the truck you need to keep on top of the maintenence of the steering motor which also has a sensor inside of it - definately not one of nissans better ideas- however getting back to your Question you can buy a Rebuilt card from your friendly nissan dealer they may ( the parts dept ) not be aware of this or to lazy to check.
The other weak piont is the pump contacter if you have transisteroised panel you are ok but if you purchased the cheap model you will be burning out the contact tips every 5 mins there is a relativly cheap fix for this let me know if you need the info.
  • Posted 2 Jun 2006 10:31
  • Reply by FrankieW
  • British Columbia, Canada
FrankieW Technician
Toyota 8FGCU20
Flesherton, Ontario, Canada
Toyota 8FGCU25
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Hoist Liftruck F180-36BOX-CAR
Toyota 02-8FD30
edition #1229 - 8 May 2025
