NISSAN GQ02L30CU DRIVE FAULT
TRUCK AS A INTERMITTENT DRIVE FAULT.
ONE MIN ITS WORKING OK THEN NO DRIVE IN FORWARD AND REVERSE.CHECKED FAULT ON IN SYSTEM CAME UP WITH F/R CTTR 516.TESTED THEM OK?
WHEN PUT IN FORWARD OR REVERSE CONTACTOR COMES IN.FOOT ON THROTTLE PEDAL NO MOVEMENT.TESTED THROTTLE POD OK.WHAT THINGS TO CHECK
  • Posted 28 May 2014 04:11
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
greasespoon,
see if the foot brake is coming back completely and the foot brake switch is in Off position. Sorry but I don't understand your explanation completely but when you have the problem the F&R contactors are activated and there's an error 516 on the display?
regards
Marc b
  • Posted 28 May 2014 05:12
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
