Nissan FD02A25Q
Suffolk, United Kingdom
Hi all, I have a problem with the Nissan FD02A25Q fitted with the TD27 engine, where the starter motor and assc relays chatter when attempting to start. The starter is good as are all the relays and it can be energised easily with a jump lead. I would wire the key directly but the neagative neutral inhibitor is sensitve and i cannot see a easy way to do this and keep the inhibitor functioning.
There is a card 25340-70K00 and relay/resistor assy? 25380-L6200 fitted on the bulkhead but i am not aware of their functions?
Does anyone know of a faulty component which may be causing this? The battery/leads/all the obvious are in excellent order.
All the best
Keith
  • Posted 18 May 2012 18:43
  • By Keef
  • joined 30 Sep'11 - 7 messages
  • Suffolk, United Kingdom
Thanks all, I've had this problem before on the JO models and suspected the same thing but couldn't pin it down. Will try again, must be something obvious i've missed.
  • Posted 21 May 2012 22:10
  • Modified 21 May 2012 22:10 by poster
  • By Keef
yup
check your frame grounds where they are directly bolted to the frame and engne block. remove the cables and make sure there is no paint behind the terminals. scrape it clean to make sure there is bare metal, reattach the cables and see if this changes anything.
the way they assemble machines these days sometimes they get in a hurry and paint over places that shouldn't be painted and the assemblers and quality control miss these things which cause tech's alot of trouble after the trucks are sold unfortunately.
  • Posted 19 May 2012 07:57
Are all of your grounds good? you may need to pull them clean them and see if that cures it and have you tried another key switch?
  • Posted 19 May 2012 06:07
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
Deborah Baker Deborah Baker
Muncie, IN, United States
Linde Material Handling
