Nissan CP1B2L25S
I have a Nissan CP1B2L25S, serial #CP1B2-000145 with a code 405(battery voltage high). Anyone have a manual or be able to tell me where to look. The code will pop up randomly.
  • Posted 18 Feb 2014 23:55
  • By Madfish
  • joined 16 May'12 - 22 messages
  • Missouri, United States
Ok and thanks for not letting us hang on what was causing the issue.
  • Posted 13 Mar 2014 10:07
  • By RCAV8TOR
  • Alabama, United States
I forgot about this topic. I found the battery was shorted on the negative side to the case. Sent the battery out to get resealed and all issues gone.
  • Posted 13 Mar 2014 10:05
  • By Madfish
Make sure battery is clean and dry and not wet from acid boils. With battery unplugged from unit, check voltage from positive battery lead to truck frame ( unplugged from truck) and is over 2/3 battery voltage is being read, clean your battery and retry. If unit has a big red disconnect switch then take the wires that are on the little micro switch mounted on bottom of disconnect switch and jumper them.
  • Posted 13 Mar 2014 10:02
  • By RCAV8TOR
Linde Material Handling
Esie Cortez Esie Cortez
TCM FD80Z7
TCM FD80Z7 1990
