mitsubushi fd30n
any info available for this truck ser ef14e03645 2012 this has tilting cab and electric brake marked grandia (might have spelled that wrong) on side panels
  • Posted 14 Mar 2014 06:31
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
the operations and maintenance manual is included with new trucks, and has the codes listing included. I think you may have a fair amount of aftermarket installed add ins, and no longer have the support of whomever was paid to install and service those add-ins.
  • Posted 18 Mar 2014 09:51
  • Modified 18 Mar 2014 09:57 by poster
at the moment we have been able to keep running with basic repairs the worst thing being transmon accerator faults and tyresaver unit all bolt ons but repairable, will try to get the book number the tech uses, i guess we are just so lucky might have to buy one, happy days you thought they might supply at least one if you buy three trucks he he oh and its got mini levers
  • Posted 18 Mar 2014 05:57
  • By trevb
not sure how much help i can be here
when i look up by serial number it does not say invalid serial number, it just tells me information unavailable.
In the manual it does pull up it has none of these things contained in it that you mention as options or anything like it.
tilting cab, electric handbrake, air conditioning
The only tilting anything i can find is in the FD33N truck with tilting control lever option.
Of course keep in mind i'm looking in the mcfa manuals and not the mcfe manuals so there is quite a few differences between what the america's have as options versus what the euro trucks have apparently.
I want to help you out but it doesn't look encouraging for me on my end.
What sort of transmission codes is it giving? i may be able to help with that :o)
  • Posted 17 Mar 2014 21:00
hello my friend, yes we are so lucky to have 3 of these, tilting ft type cab (i think), they have dry shoe system but is handbraked by an electric solenoid on lhs shoehorned in, wiring harness replaced as burns up have changed all lamps to led, also had transmission faults and to top it all airconditioning unit that i believe they no longer supply driven by lower pulley on crank that picks up all the crap and sheds the belt, lucky to have a helpful tech for info, would be gratefull for anything to help keep it running and save pestering tech these are running 20 hrs 24 7 shifts poor things
  • Posted 17 Mar 2014 05:32
  • By trevb
what problem are you having with it?
tilting cab? is this an option? very unusual for this size truck
  • Posted 17 Mar 2014 01:22
Yes you have spelt it wrong not a electric brake wet disc brakes what info do you need
  • Posted 16 Mar 2014 04:47
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Board member, UKMHA
