MITSUBISHI FORKLIFT FD100N 10tons
Hi it was my first time to join on this community, i just want to get some of your advice regarding the problem of our forklift. when it was having load the and pressing the brake it is continuously alarming and when you pull the hand brake it will run continue the forklift we already adjust the brake and full of brake fluid and the problem are still not solve. hope to get of your feed back what really is the problem.
thanks,
marionel
  • Posted 15 Nov 2014 19:01
  • By marionel_e
  • joined 15 Nov'14 - 2 messages
  • Umm Mesaieed, Qatar
i'm curious about this alarm, would this be the parking brake alarm?
i have seen in several cases where the switch on the parking brake handle will go bad or the switch arm breaks off causing the alarm to sound even when the brake handle is set.
if the alarm is going off even when seated in the operators seat then the PDS system is malfunctioning. Make sure the seat switch is operating properly, check the parking brake switch for damage.
Also when the alarm is sounding check all lights on dash and make sure none are lit up, if they are it should be determined which light is lit and what system it is associated with so you can determine where the fault is.
going on what edward is saying, if your brake linings are worn out or damaged there should be an indicator light on the dash, if any problem is detected the light will flash and an alarm will sound. Is this happening? Does your truck have the brake indicator light and is it flashing while the alarm is sounding?
  • Posted 16 Nov 2014 23:11
  • Modified 16 Nov 2014 23:22 by poster
thanks Edward, by the way the model of our forklift is Mitsubishi FD100N and the authorized services their technician can't really find the issue and can't solve the problem i will tell them to check your information given.
  • Posted 16 Nov 2014 16:04
  • By marionel_e
pull the wheels, you most likely have oil soaked shoes either from wheel cylinders leaking or (more likely) leaking wheel seals.
  • Posted 16 Nov 2014 00:07
Elwell-Parker ESI500-36
Advance CS7000
Illinois, United States
USD8,000
Tampa Florida, United States
November 3-4 2026 - Houston, United States
Advance CS7000
USD8,000
