Mitsubishi FGE10T-F25C error E87
Mitsubishi FGE10T-F25C *08059 К15 gasoline 2007.
After heating the displayed error E87
and then there's no travels back. When it gets cold traveling ok.
Seeking description eror codes, service manual.
looking for any help.
  • Posted 3 Feb 2013 23:37
  • Modified 4 Feb 2013 03:02 by poster
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
turns out, as the owner put together this loader of two similar model ( KFGE10T-KF2D * 08024 * 018762 K15 2007 and FGE10T-F25C * 08 059 * 018294X K15 2007).
obviously control unit is not of this model.
looking for wiring diagrams for one of these models, need help.
  • Posted 12 Feb 2013 00:58
  • By alexandr_k
  • Ukraine, Ukraine
hi, thanks for the help.
  • Posted 7 Feb 2013 06:43
  • Modified 7 Feb 2013 07:13 by poster
  • By alexandr_k
  • Ukraine, Ukraine
there is no E-87 in mitsu's code list for this series truck that i can find
there is however a code F-87 that refers to reverse solenoid that has been suggested.
it says could be:
1-connector contact bad
2-diode bad
3-harness bad
4-reverse solenoid bad
5-controller bad
you have a few things to check through to find this
good luck
  • Posted 6 Feb 2013 03:56
when you set the direction lever backwards you have 12v on the backwards solenoid? if yes and truck will not drive you have a problem in the transmission
  • Posted 6 Feb 2013 01:40
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
I checked the wiring and the solenoid valve,
all right, the problem remains??
  • Posted 6 Feb 2013 01:20
  • By alexandr_k
  • Ukraine, Ukraine
Hi you have a problem with the backwards solenoid on the transmission , this give the fault , check connection ore replace them
  • Posted 5 Feb 2013 04:41
  • By gc_d
Regards gc_d
Mitsubishi FGE35AT
TCM FD80Z7
TCM FD80Z7 1990
Muncie, IN, United States
Mitsubishi FGE35AT
TCM FD80Z7
TCM FD80Z7 1990
RAEDER-VOGEL
