Mitsubishi FG25N:
Mitsubishi FG25N error code E23
Good evening, the forklift truck produces E23 this code and it has no accelerator, is it the fault of the pedal - potentiometer, what is its problem?
  • Posted 6 May 2022 04:15
  • Discussion started by giorgos_k
  • Makedonia, Greece
thanks
  • Posted 12 May 2022 20:33
  • Reply by giorgos_k
  • Makedonia, Greece
- Turn the ignition key ON for 2 seconds.
- Turn the ignition key from ignition OFF for 10 seconds.
- Turn the ignition key ON for 10 seconds.
- Start the forklift.
Now the calibration is complete.
  • Posted 12 May 2022 18:27
  • Reply by Forklift123
  • Netherlands
Mechanic of Forklifts, Aerial platforms & telehandlers in the Netherlands
you can say it more simply ?
  • Posted 11 May 2022 20:43
  • Makedonia, Greece
Read accelerator pedal sensor
You can perform the calibration with the start keys:
- 2 sec. on contact.
- 10 sec. off contact.
- 10 sec. on contact.
- Start machine.
regards, Folkwin
  • Posted 11 May 2022 17:10
  • Netherlands
Thanks my friend for the answer
  • Posted 8 May 2022 13:28
  • Makedonia, Greece
I read your problem does this truck use a k21, engine and if so you are dealing with a throttle position sensor problem not a petal problem check the wiring to the throttle it is located under the main fuel injector holder on lpg it has six wires coming out two go to the motor to open the butterfly one is ground one is power and two are signal wire to the two throttle position sensor. If the wiring checks out it is possible that the two switches in side do not agree on the position of the butterfly if so you need to replace the throttle body complete hope this helps
  • Posted 8 May 2022 06:27
  • Reply by Scott_
Scott
Ncn 85TH
Ncn 85TH 2017
SMV (Konecranes) 16-1200C
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
