I have a mitsu FGC 15 with a imco lp system that is runing rich. It starts fine acel slowy fine, but under hard acel conditions it sputers then goes. Has no power under load. I have the program for the system. It shows unit runing rich. Replaced LP mixer govnor and sensors from working unit.installed new regulator. i did ign tuneup , replaced O2 sensor ,coil, and crank pic up.found problem with thermostat and clogged lins on FTP and PTV. repaired those issues and i still have the same problem. If any body can help me it will be greatly apprecated.
I checked the timeing, all the grounds and tested all the sensors, also replaced the ecm with a known good ecm. But I think I got it. Below the mixer on the right side of the unit is a cap. i removed the cap and threr was a align screw there which adjusted the air fuel ratio. Useing the computer i was able to bring into spec, and thank you again for all the help.
Had one the ecm was going out.Started popping on occasion then finally just wouldn't take fuel.
thanks i'll give it a try.
I've had some Nissan motors act like that when the ignition timing was advanced a bit from where it was supposed to be.
