mitsi fg15 fusebox
i have a wee problem in a mitsi fg15. randomly blows the top fuse in the dash fusebox. yes it,s for the transmission solenoid valve and reverse lights. but they all test out good. all wiring tests are good. does this fuse feed anything else gents. all contributions welcome. as i say fuse blows randomly ,it can be ok for days then blow 2 fuses and be ok again without lifting the bonnet. local works engineer just kept popping new fuses in. nightmare
  • Posted 19 Nov 2008 05:40
  • Discussion started by kevin_k
hello all. no phone call from the customer can only be good news. it must have been the rear lights causing the fault. hello justin ,yes this is an old girl first of the green mitsi,s over here i think,customer also runs a yellow mitsi too on their main production line !!!!. rest of the trucks are newish cat trucks.anyway fingers crossed it,s solved.thanks to all
  • Posted 20 Nov 2008 03:48
  • Reply by kevin_k
Hi kevin these type of faults can be a nightmare,what i would normally do is try to eliminate things then leave on test,can u not put the rear lights on a seperate fuse as a temp measure,or swop the solenoids and see if the fault transfers,good luck herald.
  • Posted 19 Nov 2008 18:32
  • Reply by Herald
  • lancashire, United Kingdom
what year is this truck?
assuming its basically the same as the US model
on older units with sol valves that fuse only feeds the FnR lever and the solenoids
the rev light is a switch
new units (late 90s)
it only powers the solenoids and the backup light relay coil (which is mounted to the inside of the dash cover) through the FnR lever
so since the relay is dead you get no reverse lights
the actual reverse lights are on the fuse thats second from the top
also the book lists the reverse bulbs as 10w
check the wires up to the FnR lever and the lever itself
does the lever have a small red tab that locks it in neutral?
also check for chaffed harnesses from the dash (green plug)
  • Posted 19 Nov 2008 12:24
  • Reply by justinm
I think you got a rough wire in the OHG, for the rev light circuit.
has anyone drilled into the OHG? mounted a fire extinguisher to one leg?
pinched the wire harness when putting back the lite assy.?
  • Posted 19 Nov 2008 08:49
  • Reply by edward_t
FINE KEV.....
THEM PROBLEMS ARE A PAIN IN THE A....
  • Posted 19 Nov 2008 07:07
  • Reply by DAMO
  • DUBLIN, Ireland
hows damo? i was at the thing for 3 hours today and it blew fuse once when i dropped into reverse. i thought great , dead short , easy find. tested solenoid 5 ohms resistance both coils. traced wiring from fuse into a light brown wire under the dash that was showing a bit of resistance. pulled the bulbs on reverse lights, brown wire went open circuit.only thing i thought about was 1 bulb was a 5watt and the other side was 21watt ?.replaced 21watt with another 5 watt and plugged everything back in. all worked fine. run ammeter across fuse and found draw to be around 3 amps forward and just over 4 in reverse.panels back on and belted round the place for 20 mins ,all good so heres hoping
  • Posted 19 Nov 2008 06:14
  • Reply by kevin_k
HY KEVIN
FOR A START IS THE MACHINE GOING IN ANY PARTICULAR DIRECTION WHEN THIS PROBLEM OCCURS.......HOW IS THE F/R LEVER....IT SOUNDS LIKE A LOOM PROBLEM
  • Posted 19 Nov 2008 05:52
  • Reply by DAMO
  • DUBLIN, Ireland
UN Forklift FGL25T
UN Forklift FD25T-C2JM1
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
Terberg RT223-4X4
Yale GDP100M
Flesherton, Ontario, Canada
