missing LPG components
hi, i have a Crown CG33P-3 that has had some parts removed from LPG system before the Mixer/throttle body. it has coolant hoses that should go to it and gas line from cylinder with shut off solenoid valve should connect to it, then line to mixer, can some one identify what part is missing and maybe a part number, i believe it is some sort of temp regulator for gas supply or something like that.
  • Posted 10 Feb 2017 20:30
  • By trevor_p
  • joined 10 Feb'17 - 1 message
its all fun and games til someone gets hurt
Sounds like the gas regulator/convertor. Call TVH and ask for a Woodward N2001 (Crown part XA343007), you don't want to know the Crown price believe me! Unfortunately you probably need all the relevant fittings for the gas hose outlet connection, coolant hose connections and vacuum hose too, you can probably source those locally, theyre just brass fittings. The coolant thermostatic valve TVH should be able to supply although the unit will run without it. Oh, there is one available on Ebay...take a look.
  • Posted 17 Feb 2017 20:45
  • Modified 17 Feb 2017 20:48 by poster
  • By techno_nz
  • Canterbury, New Zealand
SMV (Konecranes) 4632CC5
Hangcha FLDCXT160
Hangcha FLDCXT160
