Missing at idle
Ok here is the deal. I have been working on a lift for a while now. It has the Gm motor and it runs and accelerates great but it has a miss at idle. It had a blown intake gasket which I replaced. Runs better but still misses at idle. I have tuned it up wires and plugs. All cool pack are good. Replaced the mass air flow and cam shaft sensors. Replaced all 4 fuel injectors and it has a new vaporizer on it. I have no other vacuum leaks. It's throwing the camshaft code but it's fine all my voltage check are in specs. Anyone have any clue what to do next?
  • Posted 13 Jul 2016 00:49
  • By justin_h
  • joined 8 Jan'14 - 13 messages
  • Tennessee, United States
Sorry guys I have been tied up. I am going to look further into it tomorrow and I will let y'all know. I appreciate all the help!
  • Posted 28 Jul 2016 01:54
  • By justin_h
sorry guys that was my mistake on that camshaft code, i was working on some cat stuff at the time when i posted that and had cat /nissan codes on the brain. Should of been a 723 or 522752 code.
sorry bout that
but i am wondering where justin is in all this now?
  • Posted 28 Jul 2016 00:55
  • Modified 28 Jul 2016 00:56 by poster
That is why I asked if it is still displaying a can sensor code. Might be mis-triggering at idle.
  • Posted 27 Jul 2016 22:38
  • By BREWSKI
This is a hyster correct? Swoops last post makes me think no but the thread is under hyster ft.
Regardless I had something similar on a gm powered Yale recently. Coil pack cured it. Not saying this is what your problem is but it was for me. I know you say it's good but just saw this thread and thought I should chime in.
When you can't find a problem, fix what you know is bad. As swoop said the cam sensor can do strange things.
Edit: I had no codes displayed.
  • Posted 27 Jul 2016 21:10
  • Modified 27 Jul 2016 21:22 by poster
  • By stam
well brewski he did origionally say
but he didn't actually specifiy the code number so we can only assume it is the E28 code.
Now in some cases i've witnessed that even though the sensor is replaced the code is persistant till it is cleared via the diagnostic program or possibly can be cleared by using the 'pedal dance' or disconnecting the battery for a period of time.
In either case the engine will still run with a bad sensor, it will just be put into limp mode and turn on the MIL light once the code is picked up after a preset period of time when the ECM checks the circuit.
Now the only question that remains in my mind is did he use an aftermarket sensor? TVH?
I've had bad luck with these in the past and the only viable replacement is an OEM sensor.
Could this cause a miss? I personally have never seen it but i suppose it is possible given the function of this sensor.
  • Posted 27 Jul 2016 00:26
What code is it throwing? If there is a active code, you need to address this first.
  • Posted 26 Jul 2016 22:47
  • By BREWSKI
ok since all that checks out\
i was reading in the troubleshooting guide and there is a 'cause' section about EMI (electromagnetic interference)
how are the secondary wires from the ignition ran?
it says to check those wires and check the ground, either one can be a cause of engine missing.
  • Posted 26 Jul 2016 00:41
What should the fuel setting be? The compression checked out and there were no vacuum leaks found.
  • Posted 25 Jul 2016 23:29
  • By justin_h
run a compression check on all cylinders
could have a bad valve
also check all your vac lines, make sure there are no vac leaks.
if compresson checks ok then i'd look at the fuel system settings, could just be out of adjustment causing the miss.
  • Posted 25 Jul 2016 03:01
Toyota 8FG25
Terberg YT222
VETTER Industrie GmbH
edition #1237 - 3 July 2025
East Syracuse, United States
Saratoga, United States
Columbia, SC, United States
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
UN Forklift FGL35T
Taylor TX175
New - Sale & Hire
CEO, MHEDA
