MF0 Motor Stall
I am working on a Hyundai 20BT-9 serial no. HHKHFY08PF000032 and when it is steered left or right the motors slows and then stalls a code of MF0 Motor stall appears. Can anyone help.
  • Posted 20 Dec 2022 00:40
  • By Fatboy01
  • joined 20 Dec'22 - 1 message
Harley
The M in the error code stands for Master. Master is the right traction motor.
Lift the truck of the ground and check if you get the error. Can also be mechanical issue.
Also check if the error code isn't different turning left or right. During full turn the opposite wheel turns in the opposite way.
When it comes to the steering pot there is an improvement with shim and spring. Don't grease when you replace.
  • Posted 26 Jan 2023 17:42
  • By RSE_HMHE
  • joined 1 Nov'14 - 7 messages
  • Belgium, Belgium
Hyundai - Building a better future
Your steering axle has got an angle sensor to reduce speeds and/or when steered max left-right it will power the drive motor like a differential.
This is normal.
Parameter for the amount of cutback is called curve cutback.
Parameter Steer table should be set at option #1
FO= motor stall, the encoder signal is constantly 0 when max torque is applied to motor. I'd check the motor encoders of the drive motors and do a steering sensor calibration in the vass section.
In some cases the mechanical connection between drive axle and sensor is lost, worth checking that too.
  • Posted 21 Dec 2022 00:46
  • By Speedfreak
  • joined 24 May'18 - 103 messages
  • Niederlande, Netherlands
edition #1285 - 11 June 2026
Stu Jacover Stu Jacover
Chief executive officer, TVH
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Hangcha CBD15
China
USD1,600
Combilift Ltd
Combilift Ltd
