Message 35 and 33
Hello, I'm working on a Cat EP18K.
sn: 25111
Year of construction: 1999
The code 35 comes most, 33 occasionally.
Sometimes I get code 35 immediately if I turn the ignition on, sometimes I get it after a couple of times lifting. With a little luck I can lift a few times. Before the code is displayed, you can hear the pump running irregularly. The ampheres will be short up.
TVH has tested the board and has it approved.
(The gold plated print in the middle)
I've replaced the IGBT of the liftcontrol and the matching current sensor.
The machine has the same codes as at the beginning.
Does anybody know what the cause of the problem may be?
Mesuring IGBT:
E (lifting) 0,26 Volt
With code I get:
0,83 Volt
0,5 Volt and 0,51 Volt
Strange noise from pump motor and high Amphéres.
At 0,4 Volt no code and upon 0,42 Volt I get a code.
Measuring at the G of the IGBT:
-12 Volt
-9 Volt with powersteering
+9 Volt at fully lifting
+12 or +13 Volt with failure code
  • Posted 7 Aug 2011 06:01
  • Modified 7 Aug 2011 07:19 by poster
  • By RoojamP
  • joined 21 Feb'11 - 14 messages
  • helsmlgo, Netherlands
PM
Anyone?
  • Posted 11 Aug 2011 02:47
  • By RoojamP
Terberg RT223
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Terberg RT223
USD1
The largest butterfly in the world is the Queen Alexandra's Birdwing (ornithoptera alexandrae), with a wingspan of up to 31cm (just over 12 inches). It is an endangered species only found in Papua New Guinea.
Terberg RT223
USD1
edition #1301 - 1 October 2026
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
