Mazda cam belt,head damage ??
Chaps,
I have a Hyster 2.50 ,mid 90's with a Mazda lpg engine that has snapped the cam belt, is this a 'safe' engine ,or will it take the valves out?
  • Posted 28 Feb 2013 06:49
  • By claxby_p
  • joined 28 Feb'13 - 3 messages
  • liecs, United Kingdom
thanks chaps
  • Posted 7 Mar 2013 07:26
  • By claxby_p
FE and F2 Mazda engines are clearance engines. My suggestion is to also change the water pump, cam and crank seals while you're in there.
  • Posted 6 Mar 2013 09:54
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
Yes, Swoop is right, i have over 80 of XM´s and i never got a valve damage. It´s a safe engine definetly ! But it could happen...
  • Posted 1 Mar 2013 09:43
  • Modified 1 Mar 2013 09:44 by poster
  • By rafaelb
  • joined 14 Apr'08 - 10 messages
  • MG, Brazil
yes the Mazda UA and F2 series engines were as you call it "safe engines". The valve clearances were fairly wide so the chance of valve damage was small, not non-existent though, if the belt was to break if the engine was at high rpm's valve damage can occur. Most of the time it doesn't because the belt usually breaks during start-up.
hopefully you checked the idler tension pulley also and replaced that if need be, they can cause this to happen if they lock up from bad bearings.
  • Posted 28 Feb 2013 21:52
Thanks Lifter.
  • Posted 28 Feb 2013 07:08
  • By claxby_p
Hi claxby yes the Mazda M420G engine fitted in the Hyster XM range in the 90,s is a safe engine i worked on Hysters for over 20 years and we had quite a few cambelts snap and never had a problem with the valves or head just fit a new cambelt turn the key and everything will be ok its an easy change on these engines as well
  • Posted 28 Feb 2013 06:56
  • By lifter01
  • joined 4 Jul'09 - 461 messages
Enforcer FLBAXT25
Mobicon 2T
Bolzoni SpA (Group HQ)
Simon Manasseh Simon Manasseh
VP business development for Europe, Noblelift Intelligent Equipment Co
Regional business manager, Doosan Bobcat Material Handling
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
