lymp mode
i have gp40k at29c00499. it has a triangle luminated on dash panel. truck is in lymp mode.
  • Posted 5 Jan 2023 23:46
  • By donald_s
  • joined 26 Nov'14 - 2 messages
  • Tennessee, United States
Don Sharpe
these trucks had either an impco LP system or if it is tier2 or above it will probably have the spectrum system with the EPR regulator.
you can make it flash the error codes if you can access the diagnostic connector.
the older systems had either a flat or square connector plug marked terminals A B C D. if you jump the A and D terminals (engine off), then turn on the key and watch the MIL light (in some trucks that have the direction display on the OHG with the neutral light the MIL light is there). Once you have the diag plug jumpered you turn on the key and it will flash 3 times, pause, and then flash the code numbers with a 1 second pause between the digits, then a long pause and will start over repeating it.
If it has the spectrum system on it you will need the spectrum diagnostic module with dongle, no other way to diagnose it.
The diagnostic connector will either be under the floor plate on the RH side, or beside the distributor.
part number for the diagnostic ECU tester is 91868-02300.
cat also recommends having the service technical manual, an inductive tach and a digital vom.
  • Posted 8 Jan 2023 13:34
If this truck uses tier 2spectrum and you do not have the software to go into the truck to get the codes because this truck has a emissions problem you can jump the diagnostic connecter l believe it is a and d than count the blinks it should be a three digit code. It will first go through a count down from l believe six to one three times than will give you the code. The.codes are all three digits they will repeat three times than if any other codes will go to the next code. Hope this was of help.
  • Posted 7 Jan 2023 05:30
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
Does it have a pedal sensor for throttle? The plastic piece on the end of the pot is worn and out of range. If you have model j vaporizer with a button on it. Press while hot if it does not stall then i would start with the vaporizer and lock off.
  • Posted 6 Jan 2023 03:58
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
VETTER Forks, Inc.
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
VETTER Forks, Inc.
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
