lp fuel
I have an old s150a hyster with a f245 continental with impco fuel system. I have to hold my hand over carb to get it running, It is too lean if I choke the air system it runs fine. I have replaced the diaphram in the ca125 carb and the model J. Anyone have a clue?
  • Posted 17 Aug 2008 23:29
  • Discussion started by wellfred
  • Kentucky, United States
its allways the unexpected!
  • Posted 22 Sep 2008 17:25
  • Reply by DaveUK
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
believe it or not the problem ended up being a week coil.
  • Posted 20 Sep 2008 04:40
  • Reply by wellfred
yes justinm, good point! when I think about it I have an old syringe that I use with a short length of rubber (can I say that) hose that I use. The syringe is tight enough to hold the vacuum so you can start her up. My dad or was it my granpa? told me about "flat heads and L blocks" no just kidding!
Dave :)
PS We have gone off the subject now guys.....my fault I guess I wonder if Wellfred has fixed it yet.
  • Posted 19 Sep 2008 23:07
  • Modified 19 Sep 2008 23:08 by poster
  • Reply by DaveUK
dont su ck on the tube use a vacuum pump
if the lockoff is bad you might get a mouthful of Liquid Petroleum (ouch)
a flathead is also known as an "L-block"
  • Posted 19 Sep 2008 22:22
  • Reply by justinm
I ain't that good,,, my browser has speeel check... I can tell when I mis-peal something,,, (it gets a red line under it...)
yep,,, my bet is not enough negative air pressure at the carb...
  • Posted 19 Sep 2008 08:19
  • Reply by edward_t
Hi edward, surprised you are up yet its mid day here! you must be super awake though, your spelling is better than mine (vacuum) Glad you agree, would that be a flat head continental in the Hyster, what we call side valve?
  • Posted 18 Sep 2008 21:27
  • Reply by DaveUK
rhymes with "duck"? can you use "vacuum" as a synonym? and I agree with the idea, maybe bypassing the vff30 vacuum lockoff might work for troubleshooting...
  • Posted 18 Sep 2008 21:03
  • Reply by edward_t
you could also *** on the vaccum hose from the carb to the filter lock.............see if it starts then. If it does it could be a tired engine producing little - induction pressure under cranking.
*** the oposite to blow........the forum removes that word!
regards D
  • Posted 18 Sep 2008 20:56
  • Modified 18 Sep 2008 20:58 by poster
  • Reply by DaveUK
I am going to assume it has an impco VFF30 vacuum lockout , and a J regulator. Test the pressure coming out of the regulator @ the primary test port. pressures should run @ about 3# depending on atmospheric pressure
  • Posted 13 Sep 2008 15:07
  • Reply by Milehighlynn
  • Colorado, United States
Nagano NUZ090D
Taylor TX175
New - Sale & Hire
Taylor T520S
Toyota CORE-IC-PNEUMATIC-FORKLIFT8FGU25
Flesherton, Ontario, Canada
edition #1235 - 19 June 2025
