LP cuts out after 5 minutes every time
Pretty sure it's starving for fuel. First start of the day it will run beautifully for 5 minutes and shut off. Have to wait a minute or two to start it again, will run then for only about a minute and shut off again. Took a stab in the dark and replaced the fuel lock today. No luck. Even tried a different propane tank. Took the 5/8 rubber hose off between the regulator and the mixer - had a black gummy substance coating part of the inside of the hose, hose was soft and had a kink. Replaced it with a new hose, but still have the same problem. I did pull the vacuum hose off that goes to the filter lock when it was running and there wasn't much vacuum at all. Any suggestions what to try next? I'm pulling out what little hair I have left!
  • Posted 28 Jun 2019 07:51
  • By PonderosaPete
  • joined 28 Jun'19 - 1 message
Check the coupler on the tank hose. If the center pin is worn it will not fully open the coupler. I have had this problem in the past. Also make sure there is not a extra square seal ring in the female coupler.
  • Posted 28 Jun 2019 22:33
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Stu Jacover Stu Jacover
Chief executive officer, TVH
Elwell-Parker ESI500-36
Mobicon 2T
