lowering tilt problem
i have seen many posts about units not lowering or tilting. the seat switch open and the unit will travel did anyone figure out what it was and if so a little help would be appreciated. is there a hidden fuse on a 8FGU25
  • Posted 15 Feb 2021 18:10
  • By fish2121
  • joined 5 Mar'15 - 19 messages
  • New Jersey, United States
Likely you have corrosion in the system. there is a black control box under the left step. Many wires go to this. it needs to be taken off, under the control box is a white circuit board, here you will find the corrosion. you will need to clean or repair by soldering jumper wire across the corroded circuits.
  • Posted 18 Feb 2021 01:28
  • By Dennis_Heslop
  • joined 18 Feb'21 - 2 messages
  • Illinois, United States
Dennis
Manitou M50-4
Elwell-Parker ESI500-36
Manitou M50-4
