Lost hydraulics, not able to work
Hello, sorry if this has been asked before. I have a J35XMT2
SN H160N03702A
turned on the key and no fork operation. i can travel but not lift or lower. does anyone have any ideas as what it could be?
all fork functions do not work, lift, lower, tilt, side to side.
  • Posted 5 Apr 2019 09:21
  • By ralph_a
  • joined 5 Apr'19 - 3 messages
The battery is fully charged, and the level on the gauge shows full.
The brake fluid reservoir is half full with the cap off. This thing has me scratching my head.
  • Posted 7 Apr 2019 01:43
  • By ralph_a
well with that display it should show you the error code in such a way -02, if that is the code it is saying the forward directional switch is closed on initial startup.
But if this truck uses the monotrol pedal it defaults to forward drive anyway so that may be normal. If it has a hand selector for the directional control then it may be in a selected direction or the switch may be stuck or have a faulty switch.
As for the 'water drop' as you put it that is a drop within a circle with brackets around the circle? This is brake fluid, indicating the brake fluid is low, if the fluid is not low then the float inside the reservoir may be stuck or faulty.
since it drives but the lift does not work what is the charge level of the battery? generally the battery symbol on the dash would illuminate if the battery is low which would place the unit in battery cut out mode but if it is not lit that may not be the case but i would check the battery anyway if the level shows towards the low end of the gauge.
  • Posted 6 Apr 2019 22:52
Hello, this is my first time dealing with this type of lift, so i don't even know where to begin. there is an error code 2 on the display. also the wrench light and water drop are illuminated. The lift does not have any documentation or user manual, as it was a donation for a 501c3 company
  • Posted 6 Apr 2019 07:44
  • By ralph_a
Hello, are there currently any fault codes on the display? Example 42, 43,..
You can also look at the contactors in the counterweight to make sure they all have a good connection or aren't worn.. sometimes you can get lucky and it's just a fuse for the hydraulic pump.. please update when you can, thank you
  • Posted 5 Apr 2019 12:11
  • By joshua_h
  • joined 1 Feb'19 - 8 messages
  • Michigan, United States
Taylor TE650S
Taylor TX175
New - Sale & Hire
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
Taylor TE650S
Taylor TX175
New - Sale & Hire
