Loss of drive, forward / reverse
I think this will be a simple problem for those in the know.
It is about as basic a gas forklift as has been made.
Xmas morning, moved forklift, been sluggish drivewise for years, lost all drive.
You can select forward or reverse, feels like it has engaged, but other than a very slight movement, nothing happens.
I have a workshop manual for this model and Im reasonably ok with most mechanics.
So is it torque converter or valve which engages drive?
Any help much appreciated!!
  • Posted 31 Dec 2020 03:05
  • By Richard_Lennard
  • joined 31 Dec'20 - 1 message
  • Devon, United Kingdom
Richard Lennard
can you give a full model number? and possibly serial number?
but with that said, most transmisions in lift trucks work alot like they do in a car/truck. The torque converter does play a part but in most cases you'll find one of two things that will cause a transmission not to pull, one is low pressure due to clogged valves or filter/sump screen or possibly an inching valve problem.
second would be the worse case scenario of worn out clutch discs.
since you say you can feel it engage it could be either.
if i had a full model number i could see which model trans it has in it and can give you info on how to check it out.
  • Posted 31 Dec 2020 14:45
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
Hangcha CBD15
China
USD1,600
Hawker Powersource, Inc.
July 9-10, 2025 - Birmingham, United Kingdom
