Local service password reset
Hi,
Can someone help me with the procedure of restore the default password for "AUTHORIZED SERVICE" menu. I know that the default password is 0002468, but someone unauthorized has changed it.
Thank you!
  • Posted 22 May 2020 15:24
  • By vanoss
  • joined 1 Nov'17 - 43 messages
  • Bihor, Romania
Showing items 1 - 20 of 36 results.
The steering controller is located on the steering motor, as I understand it. It's puzzling why an error occurs specifically when lowering the forks and no other command is given. I don't see the connection between the error and the action being performed.
  • Posted 30 Jul 2024 00:07
  • By Robin_max
  • joined 29 Jul'24 - 1 message
I'm grateful for your readiness to help by answering questions.
Just wondering did you ever find the solution to this problem, I have a similar issue, steering and drive are ok but when any hydraulic function is operated fault e109 occurs
  • Posted 15 Apr 2023 21:49
  • By richardc
  • joined 15 Apr'23 - 2 messages
  • cork, Ireland
For more info i press "i" and works... the sub info is "Controller stop communicating" on first screen and at the second: "Node - EPS" and "Hex - 8131"
  • Posted 8 Feb 2021 15:35
  • By vanoss
  • Bihor, Romania
In the faultlog you can press "0" for more info.
The tapping i mentioned before is only for the old controllers with 4 or 12 leds.
  • Posted 7 Feb 2021 07:35
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
ATLET UHD
  • Posted 7 Feb 2021 06:10
  • By vanoss
  • Bihor, Romania
what is the model # that you working on now?
  • Posted 7 Feb 2021 05:53
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
In all history of 30 errors i have only the one mentioned previosly
"E109 - Steering System - sub info: Controller stop communicating"
  • Posted 7 Feb 2021 05:31
  • By vanoss
  • Bihor, Romania
what is the error code on the display, is it' only one error code or more then one, because one error trigger n other, now those steering control box is attach to the motor the motor have some small gears those get wear out so you might need to replace the motor or repair the same one,
  • Posted 7 Feb 2021 01:44
  • By GUANAJUATO
The controller of the steering is located on the steering motor, as i know... is interesting why is giving error when lowering the forks and no other command is give.... I don't see the connection between error and the command that is doing.
  • Posted 6 Feb 2021 15:28
  • By vanoss
  • Bihor, Romania
Yep, correct.
Try to tap the controller while gently lifting, you will see.
  • Posted 6 Feb 2021 07:12
  • By John50
  • Netherlands
It's a UHD, the one you refer is an UFS (i have one too at service) but this one have not front wheel turning.
It's wierd why give error at steering sistem when you give only hidraulic commands!
  • Posted 6 Feb 2021 06:18
  • By vanoss
  • Bihor, Romania
Try to slowly lift and at the same time tap gently on the controller, there is a small relais inside that somethimes is wornout.Thats always the first thing i check.
UHD is a 4 wheel truck i quess, check if the front right wheel is turning smoothly and check the 2 sensors(there should be 2 green lights on the dash to show the direction its in)Also check if the drivewheel sensors are in range.
  • Posted 6 Feb 2021 05:19
  • Modified 6 Feb 2021 05:22 by poster
  • By John50
  • Netherlands
Correct!
I have also a lots of PLL's and PLP's in service at my partners.
Now i have a wierd problem with an UHD... when lifting at maximum range and lowering is displaying the error E109 - Steering System - sub info: Controller stop communicating.
And this happend when truck is not moving and the steering commands are not actionated, only the lift/lower hydraulic commands...
Any sugestions ?
  • Posted 6 Feb 2021 04:40
  • By vanoss
  • Bihor, Romania
Top, thanks for the reply.
This dasboard is not really a sit truck nor a stand on truck.
Its a Zapi controller, so same as a PLL.
  • Posted 6 Feb 2021 04:32
  • By John50
  • Netherlands
@John
Dear colleague the command I+5+2 worked!
Many thanks and great regards!
  • Posted 6 Feb 2021 04:29
  • By vanoss
  • Bihor, Romania
I was today at truck and i tried I 5 and I 7 and doesn't work :)
Now i seen your last post... i'll try this week I+5+2.
Thanks a lot!
  • Posted 2 Feb 2021 04:35
  • By vanoss
  • Bihor, Romania
I checked today, its I 5 and 2 together, then put in batteryplug
  • Posted 2 Feb 2021 00:52
  • By John50
  • Netherlands
The truck is an "sit on stacker" with the simple keyboard controller, i tried with I 5 but doesn't work...
I put 2 links with pictures with type of the truck truck:
https://cdn.nettikone.com/live/2020/01/20/ef5de84494a95a62-large.jpg
https://st.mascus.com/imagetilewm/product/f70df7d6/atlet-xjn-160-ergo,bab04bea.jpg
  • Posted 31 Jan 2021 16:26
  • By vanoss
  • Bihor, Romania
I5 is resetting for trucks you sit on and I7 is for the ones you have to stand or walk behind.
  • Posted 31 Jan 2021 07:59
  • Modified 31 Jan 2021 07:59 by poster
  • By John50
  • Netherlands
@John
I'll be at the truck tuesday and i will try!
@GUANAJUATO
There has to be an method to reset password or master reset..
  • Posted 31 Jan 2021 06:30
  • Modified 31 Jan 2021 06:33 by poster
  • By vanoss
  • Bihor, Romania
Tusk 500PGH16
SMV (Konecranes) 12-1200B
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
