Load Wheel Replacement
Does anybody know how to replace the Load wheels on the Raymond stacker-model # 20R30TN; Serial#020R30TN7351-S
  • Posted 14 Apr 2010 03:29
  • By ray_s
  • joined 2 Oct'09 - 58 messages
  • Alberta, Canada
You have to remove the out rigger plates then it will come out as a assy.(If you have tandem load wheels). Once the assy. is removed the roll pin can be driven out of each axle.
  • Posted 15 Apr 2010 23:33
  • By scot_s
  • joined 10 Jun'04 - 63 messages
  • Michigan, United States
See if you have a set screw under each wheel if not you might have a slip ring on the inside between the wall and bearing. Good luck
  • Posted 15 Apr 2010 08:55
  • By blaine
  • joined 15 Apr'10 - 3 messages
  • Rhode Island, United States
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Taylor TX175
New - Sale & Hire
Aichi SR10C1SM
