Yale MRW030LAN24CE083:
LOAD WHEEL REPLACEMENT
I HAVE NEVER REPLACED A LOAD WHEEL ON ONE OF THESE MACHINES. HOW DO YOU REPLACE THESE LOAD WHEELS ON THE TANDEM YALE STACKER WITH REACH? DO YOU TAP OUT A SPLIT PIN OF SOME SORT?
  • Posted 21 Oct 2009 00:13
  • Discussion started by ray_s
  • Alberta, Canada
you don't mention a mast height or number, but as a general rule they either have a nut, bolt or some sort of snap ring holding the end of the cylinder's ram to the mast channel.
lift the mast into the second stage and chain it up with a properly strong chain, remove whatever attaches the cylinder ram to the mast at the top, and lower the cylinder (hopefully just using the lower function, if not you might have to put a little weight on the cylinder ram). I use a chain wrench on the gland nuts. I have had some where we had to take the cylinder out of the machine to get the gland nut loose, but far more can be unscrewed without removing anything of the cylinder barrel (jug).
  • Posted 12 Jun 2010 11:25
  • Modified 12 Jun 2010 11:26 by poster
  • Reply by edward_t
Thank-you veracitor,but I got them done now. I also need to get help on lift cylinder( RIGHT )removal if you have any suggestions on how this is done would be a great help. The serial# N482990; The model# MRW030LAN24CE085. I need to get the top seal replaced and not sure on how to get this accomplished.
  • Posted 12 Jun 2010 01:36
  • Modified 12 Jun 2010 01:38 by poster
  • Reply by ray_s
  • Alberta, Canada
hi ray_s. i can help you. what is the serial number of your forklift?
  • Posted 31 Oct 2009 23:17
  • Modified 31 Oct 2009 23:18 by poster
  • Reply by veracitor
  • Valle del Cauca, Colombia
edition #1234 - 12 June 2025
UN Forklift FD35T
Toyota 8FGCU25
Flesherton, Ontario, Canada
Hangcha 78XEN
SMV (Konecranes) 16-900C
