Load Wheel Axle Pins
Simple question here folks... Anyone else have an issue with the Crown (part number 060000-051) roll pins shearing? I have 17 RD's in my fleet with 6" load wheels. The most common "pit stop" repair is axle pins. Easy fix but drivs me crazy! Aftermarket roll pins better? I normally try to stay OE with most parts but for a $0.38 pin, too much time getting wasted!
...and yes the load wheels are properly shimmed.
Thanks!
  • Posted 29 May 2015 02:50
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
I just got a chance to check what pin 060000-081 was... I like that idea! The rolled coil pin rather than the stock spring pin. I have some 081's in my cabinet. I'll give that a try. They hold up well on the PE's...
Thanks!
  • Posted 2 Jun 2015 04:13
  • By chevotaman
Yes, Side plates, Pivot sleeve/bushing, axles, load wheels and bearings plus flatwasher shims all get replaced when they are worn/bad. Roll pins just seem to prematurely crumble and fail.
  • Posted 1 Jun 2015 23:21
  • By chevotaman
Hopefully you're also changing
065084-015 bearings
111858-002 bush
And sometimes the plates themselves,
I use the roll pin 060000-081 but they can also break, plastic also does not help.
  • Posted 30 May 2015 11:30
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
edition #1237 - 3 July 2025
East Syracuse, United States
Columbia, SC, United States
Saratoga, United States
Hangcha CPYD25XW71F-C
Flesherton, Ontario, Canada
Taylor T520M
Noblelift
