Line contactor
EP16KT ETB4B00136 I have a intermiting problem with this control the lift truck will operate fine yet stops and doesnt give me a code. Yet it may operate for a hour sometimes longer before failure. The failure is no forward or reverse no lifting just cyclying the key doesnt cure this nor removing the battery cable. Appears to me it isnt time related either as far as how long it sits. Before the lift works again so i have gone over connections and cables will the contacts for the contactors cause this problem if they are arched and pitted.
  • Posted 17 Aug 2012 22:27
  • By les_b
  • joined 17 Aug'12 - 3 messages
  • Mississippi, United States
does the display go back to showing an "E" when this occurs? or does it stay in normal mode?
to answer the question about bad contacts, it should code out if there was a bad connection there but it would only show when you press the accelerator pedal.
  • Posted 22 Nov 2012 20:42
  • Modified 22 Nov 2012 20:45 by poster
Check the relay which is under the step to board the lift, this relay may be failing.
  • Posted 22 Nov 2012 13:40
  • By hector_v
  • joined 17 Nov'11 - 42 messages
  • Puebla, Mexico
Saludos
hectorvargasm@msn.com
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Aichi SR18A
Tusk 500PGH16
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Philadephia, PA, United States
Chandler, United States
