LINDE T20 not lifting
LINDE T20 drives forward and backward, but does not lift. There is no error, only the green indicator flashes, which indicates that there is no person. Maybe someone has encountered such a problem and can help me.
  • Posted 13 Nov 2025 02:10
  • By Janis_Kibilds
  • joined 13 Nov'25 - 3 messages
  • Norway
Check for voltage at lift motor may be sticking motor
  • Posted 17 Dec 2025 03:10
  • By mobbsy
  • joined 30 Apr'13 - 25 messages
  • Cleveland, United Kingdom
thanks imobbs
Faulty or badly adjusted lift limit switch
  • Posted 16 Nov 2025 00:51
  • By lifter01
  • joined 4 Jul'09 - 465 messages
Thanks, I'll check the switch. Sorry, but I can't upload the video.
  • Posted 15 Nov 2025 02:10
  • By Janis_Kibilds
  • Norway
If the dash is saying no person it should not drive but check platform switch anyway
  • Posted 15 Nov 2025 01:57
  • By mobbsy
thanks imobbs
Hi!
I connected another battery, nothing changed. I'm running out of ideas. Attached is the number plate and display.
  • Posted 14 Nov 2025 23:40
  • By Janis_Kibilds
  • Norway
You need to send model and serial number so we can know what control panel is in it.
Because it drives and will not lift and there is not any error codes , most likely problem is low battery voltage.
  • Posted 13 Nov 2025 21:37
  • By Paddyteclinde
  • joined 3 Dec'21 - 33 messages
  • Ireland
