Linde T16
Hi all
Can someone help i have a T16 Pallet truck when i drive fwd /rev fast or slow the direction contacts drop out after approx 15 sec.
move the butterfly to centre the contacts pull in again then drop out after 15 sec.
thanks
  • Posted 22 May 2014 00:24
  • By steveo
  • joined 27 May'11 - 63 messages
  • kent, United Kingdom
Thanks to all wire broken in handle from tiller switch.
  • Posted 29 May 2014 01:40
  • By steveo
Check the tiller switch is working, I have had issues with the actuating cam wearing and the wiring breaking
  • Posted 24 May 2014 20:44
  • By jason_t
  • joined 9 Feb'07 - 7 messages
  • Hampshire, United Kingdom
Ok thanks guys i will check all parts as you suggested
regards
steveo
  • Posted 23 May 2014 23:47
  • By steveo
after seeing the parts breakdown on this tiller control my thoughts are that if there are no codes being displayed but the unit just drops out of travel and the contactor drops out you could have a hardware problem in the tiller, maybe a broken wire in the harness in the handle arm at the base where it pivots or possibly where it comes out of the motor sleve and wraps around the motor before it goes over to the control panel area.
I would check for loose connectors, make sure they are completely plugged in and the retainer is snapped all the way in. I've found on many occasions where the plugs where together but not completely snapped and the way they are designed if it is not completely snapped it might not insert the pins together completely and cause bad connections.
I find it odd though that it is not giving an error code of any sort because these units are very sensitive and almost any interruption in any circuit will cause it to display some sort of code. Even if the batteries are low that usually makes the system throw codes because of low voltage situations in the circuits that run outside of the parameters the system is setup to run at.
  • Posted 23 May 2014 20:54
  • Modified 23 May 2014 20:55 by poster
load test batteries?
checked battery connectors?
checked key switch?
checked the handle switch?
if it restarts without the key, you most likely have a bad accel pot/tiller speed control or bad contactors.
  • Posted 23 May 2014 08:08
  • Modified 23 May 2014 08:10 by poster
Hi
I checked speed sensor and changed. also no fault codes logged.
  • Posted 23 May 2014 05:06
  • By steveo
take one look for speed sensor
  • Posted 23 May 2014 01:46
  • By michel_v
  • noord holland, Netherlands
Taylor TX330S
USD159,500
JLG G12-55A
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Board member, UKMHA
