LINDE R16
Hi,
the display is off, there is NO driving forward/back , NO lift , only the steering wheel works. What can be problem?
Thank you in advance.
Dragan
  • Posted 25 Aug 2021 19:33
  • By dragan_p
  • joined 14 Dec'18 - 28 messages
  • Bosnia And Herzegovina
mbprolic hotmail com
hi dear i have the same issue with linde r16 i wnat to know ho do fix it
thanks
  • Posted 20 Oct 2025 23:35
  • By abdullah_a
  • joined 13 Apr'16 - 13 messages
  • 00966, Eritrea
oke , if you sure the 24 volt system are oke , you have power on dash and all controller. If not going on dash defect , but i think not.
  • Posted 30 Aug 2021 03:12
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
Hi,
that is not problem, I tried, where can I purchase electric schemas for this forklift truck?
Thank you in advance,
Best regard Dragan
  • Posted 28 Aug 2021 17:43
  • By dragan_p
Hi,
Best regard Dragan
  • By dragan_p
Check first 24 volt converter and circuit. Cooling fan drive motor defect , disconnect the fans and look converter on armrest have 24 volt , green led lights up. dash board shows always lights and clock time , when not 24 volt error i think
  • Posted 27 Aug 2021 21:00
  • By tr_doctor
  • Netherlands
Regards
look for fuse or camcus problem
  • Posted 27 Aug 2021 06:36
  • By michel_v
  • noord holland, Netherlands
Hi,
serial number : G1X115L01728
2000. year
Thank in advance , Dragan
  • Posted 27 Aug 2021 06:10
  • By dragan_p
serial number?
  • Posted 26 Aug 2021 17:04
  • By tr_doctor
  • Netherlands
Regards
