LInde R14 turtle on
hello.
how are you?
I write again because I'm repairing a reach truck Linde R14.
I have not diagnosis tool
I summarize a bit what I've reviewed.
The problem that arises is that when you turn on the truck, the turtle indicator is on.
The hydraulic tower commands runs smoothly. lifts and lowers; forward and backward, etc. also regulates pump speed proportional indicator always turned turtle.
The steering wheel also works fine
the parking brake is activated and deactivated without problem
if he makes an address and press the accelerator display tells you the DIR??
until there everything works like it should.
the problem is that when you press the accelerator and made ​​a slight movement indicator lights you book something like "go to manual"
but the manual says that this happens a turtle on a component temperature or low battery thing is not happening.
can give me some help besides what I've reviewed?
from already thank you very much
  • Posted 25 Jan 2013 02:21
  • By fabio01
  • joined 31 Jul'08 - 12 messages
  • uruguay, Uruguay
todo tiene reparacion, lo complejo a veces es encontrar el modo
El truck doctor y pathfinder son los dos software de diagnosis para las máquinas linde.
Truck doctor es un programa guiado y el pathfinder es mucho más completo y sirve para toda la gama. En cuanto al CANBOX es un interface que debes intercalar entre el pc y la máquina que vas a diagnosticar. Es decir, desde el pc sale un cable al CANBOX y del CANBOX sale un cable hacia la carretilla, en definitiva es un coversor del CANBUS a un lenguaje que entienda el pc.
Busca información por la red que puedes encontrar algo.
Un saludo!!
The doctor and pathfinder truck are both diagnosis software for Linde machines. Doctor Truck is driven program and the pathfinder is much more complete and serves for the entire range. As for CANBOX is an interface that must be inserted between the PC and the machine that you are diagnosed. That is from the pc goes to CANBOX cable and a cable goes CANBOX to the truck, it is truly a CANBUS coversor of a language understood by the pc. Find information on the network you can find something. A greeting!
  • Posted 2 Feb 2013 06:40
  • Modified 3 Feb 2013 11:24 by administrator
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
you nite program truckdoctor whit combox i hef to look for part NR
  • Posted 2 Feb 2013 03:19
  • Modified 2 Feb 2013 03:20 by poster
  • By michel_v
  • noord holland, Netherlands
HOla
nacsand n me puedes intruir un poco mas en como funciona esta herramienta? o para que es cada cosa
desde ya gracias
  • Posted 29 Jan 2013 10:21
  • By fabio01
  • uruguay, Uruguay
Fabio necesitarás los programas pathfinder y truck doctor, cables de diagnosis y un interface CANBOX
No es fácil conseguir todo. Busca info en internet.
Un saludo
  • Posted 29 Jan 2013 06:34
  • By nacsand_n
  • Madrid, Spain
hello
Where can i get the program truckdoctor?
and what kind of cable do I need to connect to the truck
  • Posted 28 Jan 2013 05:02
  • By fabio01
  • uruguay, Uruguay
you nite truckdocktor to repare dis truck to ment options
  • Posted 27 Jan 2013 17:06
  • By michel_v
hi powerlifter
thanks for your attention
the serial number is g1x115l00219 2000
regards
Fabio
  • Posted 25 Jan 2013 07:16
  • By fabio01
  • uruguay, Uruguay
Whats the serial number of the truck ?
  • Posted 25 Jan 2013 05:40
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
GemOne
Deborah Baker Deborah Baker
