Linde h30d no start shows codes t348 t349 t370
I have a Linde h30d, does not crank(starter is good).
Codes t348 t349 t370 show with key on. I suspect bad wiring, could someone help me figure out what these codes mean and a wiring diagram would awesome.
H30d
333735
h2x39u01835
thanks
  • Posted 17 Mar 2016 09:17
  • By usrc101
  • joined 17 Mar'16 - 10 messages
Showing items 1 - 20 of 21 results.
Can't remember codes at the moment but could be brake switches out of sink one comes in just before the other sometimes swapping over at plugs can solve it
  • Posted 31 Oct 2025 04:04
  • By mobbsy
  • joined 30 Apr'13 - 25 messages
  • Cleveland, United Kingdom
Hello,
I am having a problem with a H35T S/N H2X39W04080 with the same codes; the engine runs and hydraulic works but no forward or reverse all wires have been inspected and fuses but still no answer. I did see where the speed sensor may have been the issue I am just looking for feedback on if we would all agree this could be the issue. I have reached out to a Linde dealer seeing if I could get a service manual, but they blew me off. If anyone could help that would be amazing.
Thank you
  • Posted 23 Oct 2025 01:15
  • By Will_Hinton
  • joined 23 Oct'25 - 1 message
  • NEW HAMPSHIRE, United States
WILL HINTON
with the manual I was able to narrow it down to the injection pump or speed sensor. the speed sensor checked good, however thew injection pump did not check good.
  • Posted 13 Apr 2016 13:23
  • By usrc101
i sent you whit wytransfar
  • Posted 23 Mar 2016 09:08
  • By michel_v
  • joined 8 Mar'08 - 1,039 messages
  • noord holland, Netherlands
Still not cranking? I think that is your starting point. Did you receive the wiring of the starting circuit?
Is the key switch ok?
Is the battery ok? Also under load?
  • Posted 23 Mar 2016 05:49
  • By frits_f
  • joined 19 Dec'09 - 320 messages
  • utrechte, Netherlands
Per the linde dealer, The truck has the proper computers. So whats next lol?
  • Posted 23 Mar 2016 04:21
  • By usrc101
does anyone have a service training manual for the linde 393?
  • Posted 23 Mar 2016 04:18
  • By usrc101
I do not know I can not recall the number VW in Lindos
Normal's on the box VW also a linde NR
  • Posted 22 Mar 2016 02:47
  • By michel_v
So the Vw computer is not the right one? I guess that would explain it
Im gonna try and find a vw computer and try that
  • Posted 22 Mar 2016 02:09
  • By usrc101
linde box oke
is on vw box no linde part nummer look like 000 944 01 04???????
  • Posted 21 Mar 2016 03:34
  • By michel_v
Linde computer
R 917 002 888
390 360 14 24
  • Posted 20 Mar 2016 12:14
  • By usrc101
ok done, thanks
  • Posted 20 Mar 2016 05:50
  • By usrc101
plz add your email in your profile
  • Posted 20 Mar 2016 04:07
  • By frits_f
does not crank? IIRC the starter is wired quite conventional, so check:
keyswitch, start relay, brake switch, fuses, wiring.
but I agree codes are weird.
  • Posted 20 Mar 2016 04:02
  • Modified 20 Mar 2016 07:12 by poster
  • By frits_f
linde NR plase
  • Posted 20 Mar 2016 02:19
  • By michel_v
vw
038 906 012 JG
DIESEL EDC15VM+ 4311
BOSCH
0 281 011 365
  • Posted 18 Mar 2016 22:48
  • By usrc101
whatt is part NR off vw computer?????
  • Posted 18 Mar 2016 17:27
  • By michel_v
was not running when I got it. so anything is possible.
  • Posted 18 Mar 2016 10:51
  • By usrc101
that's certainly strange
replacing the computer?
hep you Linden laptop?
Own Creation how is this problem?
  • Posted 18 Mar 2016 07:57
  • By michel_v
thats weird cause this lift is diesel
  • Posted 18 Mar 2016 07:01
  • By usrc101
June 23-25, 2026 - Melbourne, Australia
September 15-17, 2026 - SÃO PAULO, Brazil
September 16-17, 2026 - Dallas, United States
The charge carried by a bolt of lightning is so intense that it has a temperature of 30,000-degrees C (54,000-degrees F), five times hotter than the surface of the sun which is about 5,500-degrees C (10,000-degrees F).
edition #1286 - 18 June 2026
Leading the news in this week’s Forkliftaction News , Hyster launches a new electric counterbalance forklift which it describes as “a high-performance evolution of a proven workhorse”... Continue reading
Toyota 3FD100
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Steve Strenck Steve Strenck
Director of sales, Gregory Poole Lift Systems
Vice president aftersales Europe, EP Equipment
Chief financial officer, Raymond Storage Concepts
Toyota 3FD100
USD1
