LINDE H25T-03 H2X351L035... 2000 YEAR
Hello
I have problems with this machine. Roughly starts and sometimes does not want to go forward or backward. Probably hydraulic failure, but I wanted to Linde connected via a tester, but I can not find anywhere to plug tester. Is this at all? Its leader in stone type 390 360 50 85, Type 02-BR351T.
Best regards, Laci
  • Posted 14 Aug 2012 03:27
  • Discussion started by LACI
  • Serbia
Hi Micky,
I have problem with this part too and for me it will be very very helpful if you can send me the drawing, please! I can find where to buy a new one or used one, so this is my only chance to find the drawing and try to repair it myself. Thanks a lot in advance!
Hi Laci, how are you.
Check your Email for Linde drawings.Let me know if they are correct.
Micky
  • Posted 1 Sep 2012 00:46
  • Reply by micky_h
  • South Elmsall, United Kingdom
Hello
The machine's fault is that, when heated, tugging hard to start well in advance and backward. The oil pressure is fluctuating. Separation of the oil pump is in bold and the control block. To do this, it would be some kind of exploded drawings and printing settings data.
Best regards, Laci
  • Posted 31 Aug 2012 21:56
  • Reply by LACI
  • Serbia
Thanks Michel
Best regards, Laci
  • Posted 27 Aug 2012 16:06
  • Reply by LACI
  • Serbia
Thanks Michel
Best regards, Laci
  • Reply by LACI
  • Serbia
i ken sent you one book
  • Posted 26 Aug 2012 17:45
  • Reply by michel_v
  • noord holland, Netherlands
zo far i no type 351 dond hef laptop dianosticks
best regards michel
  • Posted 26 Aug 2012 17:27
  • Reply by michel_v
Thanks,
  • Posted 26 Aug 2012 14:53
  • Reply by LACI
  • Serbia
In 350 series this connector is located beside valve block.
Check your mail.
Regards
  • Posted 26 Aug 2012 05:14
  • Reply by nacsand_n
  • Madrid, Spain
Hello
The question is still relevant. I can not find where is the diagnostic connector!
best regards, Laci
  • Posted 26 Aug 2012 02:30
  • Reply by LACI
  • Serbia
not be giving my mail does not allow me, all operate at pressures of oil but there are mechanical and other electronic
  • Posted 14 Aug 2012 04:30
  • Modified 14 Aug 2012 04:36 by poster
  • Reply by juanpascual_t
  • Spain
Jhon_T
This machine are set to the pressure on the valves, and why I think that pressure error. But if anyone knows that this is and where the service is connected to the tester?
  • Posted 14 Aug 2012 04:24
  • Reply by LACI
  • Serbia
Hello Juan.
Please your email adress. My is in my profile
  • Posted 14 Aug 2012 04:18
  • Reply by LACI
  • Serbia
Hello there are two versions of the year 2000 with control unit if it is that, apparently have the problem in the throttle potentiometer.
If it is an older model the failure must be in the hydraulic throttle body.
Jhon_T
edition #1235 - 19 June 2025
VETTER Industrie GmbH
