LINDE H20t, Error codes T225 and T235
I have a Linde H20T, Serial Number H2X391000093. It will ramdomly display error codes T225 and T235. The machine will not move while the code is displayed, but if you shut it off and wait a few minutes it will clear on the restart. Any help would be appreciated.
  • Posted 12 Apr 2013 01:05
  • By Wajaxed
  • joined 16 Feb'10 - 23 messages
  • British Columbia, Canada
If it wasn't for human error and negligence, I would have nothing to do most days.
Stay safe
Ed
pls send code T 235
pls send error code detels and how to solve the problem
  • Posted 4 Mar 2020 15:53
  • By Shriram_Ghule
  • joined 4 Mar'20 - 1 message
  • India
Sds
I had this problem this morning and corrected it. The code indicates the forward/reverse selector lever needs to be replaced.
  • Posted 29 Aug 2017 06:24
  • By Gprice0616
  • joined 29 Aug'17 - 1 message
  • GA, -
Is it one pedal or two pedal version?
If it's one pedal, check the direction switch (probably here's the problem), eventually check the wirings between the direction switch and N1 module. (particulary (N1:36, N1:37, N1:72).
It's possible that this errors appear when the truck works in strong magnetic fields, but it's rather rare situation.
If it's two pedal version,
the X1, the coding connector is faulty, or the wirings between X1 and module N1 (the same pins as above) are faulty.
  • Posted 12 Apr 2013 01:52
  • Modified 12 Apr 2013 02:05 by poster
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
JLG G12-55A
TCM FD115-3
