Linde H16D 391 cam belt
Just had a Linde H16D 391 come in with a snapped cam belt.
Does anyone know if these always do damage when the belt breaks and has anyone got the procedure for timing one up.
Cheers,
  • Posted 7 Apr 2010 02:25
  • By danny_k
No,
I verrified the brakes also electrical and mechanic.The electronic control plate is not the original one.
  • Posted 12 Apr 2010 21:59
  • By Octav
  • joined 26 May'08 - 12 messages
  • Buzau, Romania
algobuzau@yahoo.com
My customer has been very lucky. Timed it up, put a belt on it and it runs sweet. Water pump was leaking though so just put one on. If it would have been my truck it would have blown its self to bits!! Thanks for your help guys!!
  • Posted 12 Apr 2010 21:55
  • By danny_k
The problem with the E15 sound like a bad parking brake switch.
  • Posted 12 Apr 2010 21:31
  • By duodeluxe
  • United States
  • By duodeluxe
  • United States
Yes you are correct 3000hrs is correct for replacement
  • Posted 9 Apr 2010 06:24
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Isnt the belt replacement service interval like every 3000 hours by normal work 2500 hours by heffy work
and dont vergot waterpomp
best gegards michel
  • Posted 9 Apr 2010 01:18
  • By michel_v
  • noord holland, Netherlands
Isnt the belt replacement service interval like every 4000 hours? Not sure about this but I know its not too long with the VW motor.
  • Posted 8 Apr 2010 22:06
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
Hi danny you may find you could have some bent valves if belt has snapped, how many hours has it done. Try to fit a belt and you will see if it will run. The timing marks for the crank are seen through the hole on the bell housing you will see a pin on the bellhousing and a mark on the flywheel, the camshaft has a tdc mark on it, the injection gear has a slot in it and a hole in the casing behind the gear at about five-ten past use a drill bit in the hole 6mm springs to mind. Also replace belt adjuster.
You may get it started but fine tuning to the injection pump can only be done with laptop,
The correct timing tool is available from VW dealers if you give them a engine number, this consists of a pin for the inj pump and a cam locking tool, but you may still need the laptop to time pump.
hope this helps
herald
A timing tool
  • Posted 8 Apr 2010 04:08
  • By Herald
Hi Michel,
It is a VW engine.
  • Posted 7 Apr 2010 08:02
  • By danny_k
is it vw ore renauld engine ?
  • Posted 7 Apr 2010 06:19
  • By michel_v
dond vergot waterpomp
  • Posted 7 Apr 2010 06:16
  • By michel_v
