Linde E30 336-2
when changing bearing in drive motor the bearing on NDE is burned wery much,
Is there a solution on this problem.
E30 336-2 ser: G1X336L01913 year 2000
Have changed bearing before on same truck some years ago began to be noisy after 5-6 month. Not sure if i eill let it drive mutch longer with bearings.
  • Posted 14 Oct 2009 05:23
  • Discussion started by bjarte
  • 5911 Alversund, Norway
post at 2talservice dot no
do stop 4 new lower and you can 6000 hours
  • Posted 15 Oct 2009 06:01
  • Reply by michel_v
  • noord holland, Netherlands
  • Reply by michel_v
There is no other problem with drive than wheening noise from motors depending of speed
Have 5700 Houres have no hard use
  • Posted 15 Oct 2009 05:54
  • Reply by bjarte
how does much drive hours have this truck? the truck on its electronica slows down normally and prevents a lower and time in 6 a 7 ooo hour
  • Posted 15 Oct 2009 03:25
  • Reply by michel_v
Hi
for me it seem to go power throu the bearing it is just on the side with the brake on both drivemotor the other end have no problem, have thinked to mount ceramic bearing. no it stand a standar2rs C3. Is there somone that know if there have been a service buletin on the isue?
  • Posted 15 Oct 2009 02:58
  • Reply by bjarte
tel me moor info of dis problen
best regard michel
  • Posted 15 Oct 2009 01:53
  • Reply by michel_v
Aichi RX07B
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
edition #1229 - 8 May 2025
Noblelift
