linde E20P-02 ERROR CODE 45 AND 39 DONT WORK ANITHING
hello
I have a problem with a forklift LINDE E20P-02 serial h2x335m01039 Year 2001
truck does not make any order or hydraulic drive and on my truck error codes appear doktor 45 and 39.
Can you help me with this problem
thanks
  • Posted 3 Apr 2013 17:18
  • By adi_m
  • joined 5 May'12 - 75 messages
  • romania, Romania
adi
e mail adress metadonul @ hotmail dot com
Did you check the voltages on the pins I specified?
Check the voltage on X11:1 and X11:11.
If the voltage there is lower than 30V check the routes I speicfied above.
Than between X11:15 and X11:1 and between X11:15 and X11:11
If it's higher than 8V check the routes.
X11 is the big 42-pins connector on A1 (traction module).
  • Posted 3 Apr 2013 20:57
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
I tried with another battery and so does not start anything
LDC is
may be faulty power panel
  • Posted 3 Apr 2013 20:28
  • By adi_m
  • romania, Romania
adi
Hello
Both codes apply to the lack of power.
First of all - check the battery. Both errors show it maybe discharged or faulty.
Ewentually (if it's LDC):
error 39 - The voltage is to low
on pin x13:1 and x13:11 lower than 35V
Check the routes: 1X11:1 - F8 - A1:2
or 1X11:11 - 1F6 - 1A1:2
or F8:2 - X12:4 - R1 - 1R1 - X12:2 -1F6:2
or 1X11:2 - 1F2 - S2 - X10:L+ - G1
Error 45
Voltage difference between 1X11:15 and 1X11:1 > 8V
or
Voltage difference between 1X11:15-1X11:11 > 8 V
The above data applies to LDC version of 335-02
if it's LLC or with LDC/LLC with Kombi it maybe slightly different
Check these, but in my opnion -it's battery.
  • Posted 3 Apr 2013 20:17
  • By Karait
  • Poland
J.M.
Mitsubishi FD200
Terberg RT223
Deborah Baker Deborah Baker
