linde E15-02
Hello, i am working in linde E15-02 serial H2X324P01429
the lift truck some time work but other don't do nothing no click nose on contactor, check the post and manually i adjust the post position, swith off and on and holding the position in the post and i listen a click on the contactor put it back on place and the truck work untill i dipress the accelerator and press to travel it simple don't do nothing
  • Posted 26 Apr 2011 03:44
  • By JHpantaleon
  • joined 26 Jun'10 - 13 messages
  • distrito, Dominican Republic
controller reads microswitch on accel pedal.
3 pins, one wire is common, has to have continuity when in open position, then continuity when in closed position
  • Posted 26 Apr 2011 10:21
  • By ddrr
  • joined 27 Jul'06 - 16 messages
  • Alberta, Canada
it is 24 volt, i checked the micro switch it is ok i read a little variation on ohnm as i dipress the pedal about 1.3 ohm
  • Posted 26 Apr 2011 08:09
  • By JHpantaleon
7777;
Is the truck a 24V or 48V. This is needed to define the control circuit arrangement.
  • Posted 26 Apr 2011 06:59
  • By MEngr
  • Missouri, United States
start off simple and basic, check the micro switch on the accelerator pedal.
  • Posted 26 Apr 2011 05:46
  • By 7777
Libiao Robotics
