Linde (& Baker) E 14-02:
Linde E14-02 tilt error 36)
Hey,
I have a Linde E14-02 (335) forklift, it has error 36 on (joystick tilt error).
The tilt function of the mast sometimes fails as a result.
I have read the tilt joystick, these are +/-14% sent out. If I install a new one, the problem remains the same. calibration doesn't work either.
If you switch off the machine from the ignition, it is just as good (0% control tilt joystick) after a few minutes this percentage starts to increase.
I have measured the wiring harness from joystick to controller, it is also good.
Does anyone have an idea where I should look for the problem?
  • Posted 24 Sep 2021 00:20
  • Discussion started by Forklift123
  • Netherlands
Mechanic of Forklifts, Aerial platforms & telehandlers in the Netherlands
Hello....weard problem....maybe the controller is broken but before that i think you should take out the anti static....if u have gray tires problem will incrise. ground your lift truck with anti static strap and joystick pad too. (wire to frame)
  • Posted 27 Sep 2021 02:27
  • Reply by Justus
  • Finland
Louisville, KY, United States
Dubuque, IA, United States
Terberg YT182
UN Forklift FBR25NQC3
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
