Showing items 1 - 15 of 102 results.
Hallo do you have Can box USB drivers??
Hallo do you have drivers to can box USB??
Hallo do you have drivers to can box USB Linde you can send me this drivers??
Hallo do you have drivers to can box USB. You can sent mi this drivers
Hallo I need drivers to my can box Linde USB. Do you help me??
Do you have Can box Linde drivers??
Hallo I have Can Box USB I do not heve drivers. Can you help me, please send me this drivers ifb you can thanks
Hi did you get driver for Linde Canbox USB ?
if you do can you give it to me too ?
Thank you
Dear frineds ,any one can help with the canbox 3 driver for windows 10.
badr.industry(a)gmailcom
Thanks in advance
Hi,
just seeking some help getting the linde canbox drivers. can you point me in the right direction.
Thanks
Mario
Antonio,
If you still require support you can contact me. See my profile for contact details
Antonio,
Config the Com ports: latency 16, read timeout 5000, write timeout 5000 and not check Serial Enumerator
After this, in LNH Starter at Hardware config set to use the USB CAN-Box II (orange cable), you can set it to use with Flasher, Pathfinder and Truckdoctor.
Hello Michel
It seems you have some good experience with Linde Canbox and wondered if you could help? I have several engineers with the old style canbox but I recently bought another one for an engineer (Canbox II Part No. 253005019) I also have version 3.6.1 of pathfinder but whatever I do I cannot get it to link up to the truck. I have tried moving the com ports to com 1 and com 2 but still will not connect. I saw that you mentioned previously about config pathfinder com. Is this something different to the com ports shown on device manager? I have four different drivers showing on the cd that came with the canbox and I take it the correct driver is "CANBOX II 3903605141 USB" I managed to get the CANBOX to light up all of the four led lights on the box but it still wont connect.
Would really appreciate it if you could help
