Tengo Mismo error en una C90 el error es L256 ya tiene cableado y ecu mastro nuevo , hemos hecho de todo pero el error sigue solo nos queda probar la ecu eesclavo pero no tenemos una maquina igual para la prueba me pueden ayudar
Please use English Language:
Littoral Translation...I have the same error on a C90, the error is L256, it already has wiring and a new master ECU, we have done everything but the error continues, we only have to test the slave ECU but we do not have an equal machine for the test. Can you help me?
Sebachofa I can help you, contact me by email
Hi, we have a fault code on a Linde C90. The fault code is T228 - X418. I'm from Argentina and we don't have any manual or support office of Linde here. Anybody can help us ?
L prefix =lift/tilt fault
is trying plugs exchange joysticks
allow me something that I did the same and that turned out to be in the joystik
HI WE THINK ITS THE ECU, BUT THERE IS NOT MANY C90 AROUND TO TRY THE ECU ON. HOPEFUL I MIGHT BE ABLE TO PLUG IT IN TO ANOTHER MACHINE NEXT WEEK. NEVER HAD A ECU FAULT WITH A LINDE BEFORE THO, BUT THERE IS ALWAYS A FIRST TIME!!!
THANKS FOR THE REPLY
The ECU is ok?You can try the ECU on a different machine?
