Hi
I am having the same problem, did you find the fault ?
Have checked all fuses and seat switch. Spanner and fork cut out lit on dash, no drive and no lower or tilt but side shift and raise.
thanks
Gary
Good Day, mplco
You say the wrench & seat switch or OPS dash lights were staying on along with the the mast going up but not lowering & no tilt.
I have a 8FGU25 & thats the problem we still have not figured out. You said you adjusted the main hyd pressure at the control valve ? The deal with your sideshift being slow is that there are restrictor's in each line to the cyl that can be removed. Still I'm wondering about this pressure adjustment thing? Waiting for your reply. Thanks, Paul
hello rogeriwt,
thanks for you quick respond, No- on this case all fuses was OK (I checked it @ a firts time- all of them) I got the problem: i re-adjust pressure on master valve ; but- be aware -do not lost speed on the side shift cilinder - a movement of side shaft cylinder were so slow; need to go back to close to original position.
Thanks mplco
Check all the fuses. I ran into this once and the material handling ecu had blown the fuse. It sounds like that is what happened to you. Good Luck.
