Lift Limt
Hi all,
I'm working on a Yale orderpicker who makes ''Lift Limt'' when I try to go up. The traction don't work too... I don't have the ''Lift Limit'' switch on this unit.
I tried a new mast's pot, reset the card setting, the proximity switch at the bottom of the mast works well... but nothing change.
Anyone have any information about this unit ? I'm out of idea
Thank you !
  • Posted 6 Nov 2018 10:23
  • By Meden64
  • joined 13 Jun'17 - 11 messages
  • Quebec, Canada
My mast height was 378... I did exactly what you said and now the OPC works well.
Thank you for your help and your time!
  • Posted 8 Nov 2018 10:47
  • By Meden64
  • Quebec, Canada
Go into the one DiagDisp. Scroll to Lift Hgt. This will show you what the system thinks your mast height is. If it is not 0, loosen the encoder and rotate it until it is at 0.
  • Posted 7 Nov 2018 09:29
  • By BREWSKI
The serial number is D826N02870E.
The only settings I have in the dash are :
-ThrtV
-Default
-SmallBox
-WheelStr
-Str Gear
-3-Stage
-Str GN 3
-Max Sp 5
-Accel 4
-NtBrk 3
-RsBDI229
-0%BDI179
-Cal 254
-Switch 1
-Switch 2
-DiagDisp
-Error Log
-Sr#2920
-PC#16000
  • Posted 7 Nov 2018 08:48
  • By Meden64
  • Quebec, Canada
Do you have the serial Number?
  • Posted 7 Nov 2018 08:04
  • By BREWSKI
Do you have access to the dash? You need to see where the encoder height is at with the mast lowered. It is probably over max lift height. You need to reset to 0. I will see if I can find the reset procedure.
  • Posted 7 Nov 2018 07:56
  • By BREWSKI
Hi,
I check the setting in the 1310 controller. I don't have the "LwrLm" setting...
I reset the card's setting (Default) too and nothing change.
Thank you
The model number of my unit is OS030BEN24TE095... I didn't chose the right one in the forum, my bad
  • Posted 7 Nov 2018 04:58
  • By Meden64
  • Quebec, Canada
lift encoder on mast determines lift height based on settings in the 1310 controller.
You can access the system through the dash by pressing the horn button twice real quick when you turn on the key before the horn sounds during self check.
Then navigate to the LftLmxxx and make sure it is set to 380in.
The scroll to LwrLmxxx and make sure it is set to 0in.
Do not adjust any other settings unless you know what they are supposed to be.
You could do a full default reset but you WILL NEED TO KNOW what systems the truck has and its steering type etc. I would not advise this unless you know this information.
  • Posted 7 Nov 2018 00:25
Deborah Baker Deborah Baker
MAXAM Tire, Inc.
Muncie, IN, United States
